[gdal-dev] PROJ6?
Even Rouault
even.rouault at spatialys.com
Fri Feb 1 12:25:10 PST 2019
On vendredi 1 février 2019 23:20:58 CET Darafei "Komяpa" Praliaskouski wrote:
> https://github.com/postgis/postgis-build-env
Looking at https://github.com/postgis/postgis-build-env/blob/master/Dockerfile
, it looks like you're building PROJ after GDAL. This should be the other way
round. GDAL used to be able to load PROJ with dlopen() mechanism, but this is
no longer the case, so proper compilation order is now needed.
Even
http://www.spatialys.com
