[gdal-dev] ogr2ogr giving postgres source a specific ogr layer name
andrew terry
andrew.terry at centremaps.co.uk
Tue Feb 5 04:03:53 PST 2019
Is it possible to give postgres -sql output a specific ogr layer name.
As i understand it - In order to create DXF blocks, i need my postgres table
(and therefore ogr layer name) to be called blocks.
Is there a way to force the ogr layer name being used.
I tried -sql "SELECT * FROM (SELECT * FROM public.table) blocks" without
success
I don't want to use a view table as i'm hoping to use a function on some
occassions
Andy
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
