[gdal-dev] ogr2ogr giving postgres source a specific ogr layer name
    andrew terry
    andrew.terry at centremaps.co.uk
    Tue Feb  5 04:24:34 PST 2019
Apologies - i see -nln works both when using sql or just calling a table
andrew terry wrote
> Hi,
> Is it possible to give postgres -sql output a specific ogr layer name.
> As i understand it - In order to create DXF blocks, i need my postgres
> table
> (and therefore ogr layer name) to be called blocks.
> Is there a way to force the ogr layer name being used.
> I tried -sql "SELECT * FROM (SELECT * FROM public.table) blocks" without
> success
> I don't want to use a view table as i'm hoping to use a function on some
> occassions
> Andy
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
