[gdal-dev] MSSQL Driver on Mac
Horn, Ian I (COT) Ian.Horn at ky.gov
Wed Feb 13 06:13:57 PST 2019
I am trying to access a SQL Server on QGIS, but I get the “error opening connection:  Driver not loaded Driver not loaded”.  QGIS installs GDAL 2.3.2.  On my PC I know how to get to the root folders and check to see if the driver is there but not on my Mac.  If I use my terminal I get the following:
Unable to open datasource `mssql:server=XXXXXXXXX;database=XXXX;tables=XXXXX.TrafficCameras;XXXXXX;
' with the following drivers.
How do I install or make this driver work on my Mac for both command line  and use in QGIS?
Thanks,
Ian
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190213/955cc733/attachment-0001.html>
