[gdal-dev] MSSQL Driver on Mac
Peter Petrik
peter.petrik at lutraconsulting.co.uk
Wed Feb 13 06:26:06 PST 2019
Hi, which installation do you use?
Cheers,
Peter
On Wed, Feb 13, 2019 at 3:14 PM Horn, Ian I (COT) <Ian.Horn at ky.gov> wrote:
> I am trying to access a SQL Server on QGIS, but I get the “error opening
> connection: Driver not loaded Driver not loaded”. QGIS installs GDAL
> 2.3.2. On my PC I know how to get to the root folders and check to see if
> the driver is there but not on my Mac. If I use my terminal I get the
> following:
> Unable to open datasource
> `mssql:server=XXXXXXXXX;database=XXXX;tables=XXXXX.TrafficCameras;XXXXXX;
> ' with the following drivers.
> How do I install or make this driver work on my Mac for both command line
> and use in QGIS?
> Thanks,
> Ian
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190213/a0a61fdb/attachment.html>
