[gdal-dev] MSSQL Driver on Mac
Andreas Oxenstierna
ao at t-kartor.se
Wed Feb 13 06:27:54 PST 2019
What is ogrinfo reporting?
ogrinfo --formats | grep MS
For me (macOS 10.14.2 GDAL 2.3.2) it reports:
MSSQLSpatial -vector- (rw+): Microsoft SQL Server Spatial Database
> I am trying to access a SQL Server on QGIS, but I get the “error
> opening connection: Driver not loaded Driver not loaded”. QGIS
> installs GDAL 2.3.2. On my PC I know how to get to the root folders
> and check to see if the driver is there but not on my Mac. If I use
> my terminal I get the following:
> Unable to open datasource
> `mssql:server=XXXXXXXXX;database=XXXX;tables=XXXXX.TrafficCameras;XXXXXX;
> ' with the following drivers.
> How do I install or make this driver work on my Mac for both command
> line and use in QGIS?
> Thanks,
> Ian
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Hälsningar
Andreas Oxenstierna
T-Kartor Geospatial AB
Olof Mohlins väg 12 Kristianstad
mobile: +46 733 206831
mailto: ao at t-kartor.se
http://www.t-kartor.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190213/0fbf5c3a/attachment.html>
