[gdal-dev] Convert jpg to geotiff
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Wed Feb 20 02:33:02 PST 2019
Hi Ashwin,
which GDAL version are you using?
JPEG format doesn't support geospatial information (it's a pure image) so
when you convert GeoTIFF to JPEG,
GDAL takes care of writing geospatial info into an external auxiliary file:
yourfile.jpg.aux.xml.
So, when converting back JPEG to GeoTIFF, make sure that
yourfile.jpg.aux.xml is still around so that GDAL can use it to write back
that info when producing the GeoTIFF.
alternatively, you may force spatial extent and coordinate reference system
using -a_ullr and -a_srs parameters on your gdal_translate command.
Cheers,
Daniele
On Wed, Feb 20, 2019 at 11:22 AM Ashwin Nair <ashnair0007 at gmail.com> wrote:
> Hi,
> I was able to convert my geotiff images (from the Spacenet dataset) to
> jpgs using gdal_translate but I would like to know how to convert the jpgs
> back to geotiff. I tried using gdla_translate as is, via gdal_translate -of
> GTiff in.jpg out.tif but wasn't able to get back the original geotiff
> image as there was a difference in the coordinate system. I'm new to
> working with satellite images so I'm not entirely sure about the process.
> Best Regards
> Ashwin
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Regards,
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:      +39 0584 1660272
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190220/944ff78a/attachment-0001.html>
