[gdal-dev] Convert jpg to geotiff
Daniele Romagnoli
daniele.romagnoli at geo-solutions.it
Wed Feb 20 05:07:18 PST 2019
Cool.
I'm keeping the list in the loop so anyone having similar issue in future
can see this feedback.
Cheers,
Daniele
On Wed, Feb 20, 2019 at 2:00 PM Ashwin Nair <ashnair0007 at gmail.com> wrote:
> Hi Daniele,
> That was exactly it. I had previously removed the accompanying jpg.aux.xml
> file which was why I wasn't able to convert the jpg properly to Geotiff.
> Thank you very much.
> Best Regards
> Ashwin
> On Wed, Feb 20, 2019 at 2:32 PM Daniele Romagnoli <
> daniele.romagnoli at geo-solutions.it> wrote:
>> Hi Ashwin,
>> which GDAL version are you using?
>> JPEG format doesn't support geospatial information (it's a pure image) so
>> when you convert GeoTIFF to JPEG,
>> GDAL takes care of writing geospatial info into an external auxiliary
>> file: yourfile.jpg.aux.xml.
>> So, when converting back JPEG to GeoTIFF, make sure that
>> yourfile.jpg.aux.xml is still around so that GDAL can use it to write back
>> that info when producing the GeoTIFF.
>> alternatively, you may force spatial extent and coordinate reference
>> system using -a_ullr and -a_srs parameters on your gdal_translate command.
>> Cheers,
>> Daniele
>> On Wed, Feb 20, 2019 at 11:22 AM Ashwin Nair <ashnair0007 at gmail.com>
>> wrote:
>>> Hi,
>>> I was able to convert my geotiff images (from the Spacenet dataset) to
>>> jpgs using gdal_translate but I would like to know how to convert the jpgs
>>> back to geotiff. I tried using gdla_translate as is, via gdal_translate
>>> -of GTiff in.jpg out.tif but wasn't able to get back the original
>>> geotiff image as there was a difference in the coordinate system. I'm new
>>> to working with satellite images so I'm not entirely sure about the
>>> process.
>>> Best Regards
>>> Ashwin
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Regards,
>> Daniele Romagnoli
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Daniele Romagnoli
>> Senior Software Engineer
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054 Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
Regards,
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
GeoSolutions S.A.S.
Italy
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190220/5d3112bc/attachment.html>
