[gdal-dev] Can't compile GDAL 2.4.0 with Visual 2017 - 32 bits
PROVIN
rprovin at altoa.fr
Thu Feb 21 05:18:08 PST 2019
Hello,
I am trying to compile GDAL (version 2.40, but I also tried 2.3.1) with
Visual 2017 in 32 bits.
I used the generate_vcxproj.bat to generate my Visual project / solution,
this way (as indicated) :
generate_vcxproj.bat 15.0 32 gdal_vs2017
The compilation gives the following error :
fatal error C1083: Impossible d'ouvrir le fichier include : 'stdio.h' : No
such file or directory (compilation du fichier source cpl_list.cpp)
I have this error for all the files cpl_XXXX.cpp of "port" folder.
It is strange because these files are accessible when I right click on the
line
#include <stdio>
and open the file.
I tried to retarget the project, tried to reinstall Visual 2017.
I would be glad if anyone had any advice !
Thank you,
REMI
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190221/10c6f056/attachment.html>
