[gdal-dev] Shapefiles encoded in UTF-16 ?
Even Rouault
even.rouault at spatialys.com
Thu Feb 21 07:28:24 PST 2019
On jeudi 21 février 2019 14:11:15 CET Andreas Oxenstierna wrote:
> More relevant question should be if OGR support GeoPackage in UTF-16, as
> this is defined in the spec.
From a quick test (dumping an existing GPKG as SQL statements, inserting a
PRAGMA encoding='UTF-16le' at the beginning of it and regenerating a SQLite3
database from it), it supports them on reading&update. This is mostly an
internal detail of SQLite itself
http://www.spatialys.com
