[gdal-dev] Can't compile GDAL 2.4.0 with Visual 2017 - 32 bits
PROVIN rprovin at altoa.fr
Mon Feb 25 07:42:37 PST 2019
Hello Joaquim,
Thank you for answering ,
I run nmake from within the x86 Command prompt for VS 2017, and no I had not
previously run that batch.
I just tried that tough, and ran the command :
vcvarsall.abt  x86  10.0.17763.0
(that's my version of the windows SDK), I got "The specified configuration
type is missing. The tools for the configuration might not be installed".
Do you know what it means ?
Thanks,
Rémi
De : Joaquim Manuel Freire Luís [mailto:jluis at ualg.pt]
Envoyé : lundi 25 février 2019 12:23
À : PROVIN; gdal-dev at lists.osgeo.org
Objet : RE: [gdal-dev] Can't compile GDAL 2.4.0 with Visual 2017 - 32 bits
You are running the nmake command from within a cmd window where you had
previously run the vcvarsall.bat for 32 bits, right?
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of PROVIN
Sent: Monday, February 25, 2019 2:45 PM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Can't compile GDAL 2.4.0 with Visual 2017 - 32 bits
Hello Jeff,
Thank you for your answer, I had tried that already (I usually compile GDAL
this way with NMAKE),
but I had the exact same error.
Maybe this has to do with my installation of Visual Studio ?
Remi
Hi Remi,
Personally I'd recommend using the provided nmake.opt inside GDAL's root
directory, and modifying that for your own local libraries.  (note that
the cleanest way to do this is to create a new file 'nmake.local' and
put your settings in there, leaving the distributed nmake.opt as
reference only, and then execute that with the command:
        nmake /f makefile.vc
(others may recommend using the *.bat magic, but sometimes the raw
commandline is more fun ha)
Have a nice weekend,
-jeff
On 2019-02-21 9:18 AM, PROVIN wrote:
> Hello,
> I am trying to compile GDAL (version 2.40, but I also tried 2.3.1) with
> Visual 2017 in 32 bits.
> I used the generate_vcxproj.bat to generate my Visual project /
> solution, this way (as indicated) :
> generate_vcxproj.bat   15.0 32 gdal_vs2017
> The compilation gives the following error :
> fatal error C1083: Impossible d'ouvrir le fichier include : 'stdio.h' :
> No such file or directory (compilation du fichier source cpl_list.cpp)
> I have this error for all the files cpl_XXXX.cpp  of "port" folder.
> It is strange because these files are accessible when I right click on
> the line
> #include <stdio>
> and open the file.
> I tried to retarget the project, tried to reinstall Visual 2017.
> I would be glad if anyone had any advice !
> Thank you,
> REMI
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
sgn
Rémi PROVIN
Ingénieur géomatique
 854 route de Rémire - 97354 Rémire Montjoly
tél : 05-94-25-61-93 - fax : 05-94-25-61-94
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190225/323692b4/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190225/323692b4/attachment-0001.png>
