[gdal-dev] Can't compile GDAL 2.4.0 with Visual 2017 - 32 bits
Joaquim Manuel Freire Luís
jluis at ualg.pt
Mon Feb 25 07:47:45 PST 2019
You would run it with a command like this
"C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build\vcvars32.bat" x86
I do it this way because I also want to control the path and thus avoid contamination from other parts of my otherwise potentially messy environment. But since you run from the "x86 Command prompt for VS 2017" the vcvars32.bat was already run for you so no need to worry about that. The source of your trouble must me than be something else.
Hello Joaquim,
Thank you for answering ,
I run nmake from within the x86 Command prompt for VS 2017, and no I had not previously run that batch.
I just tried that tough, and ran the command :
vcvarsall.abt x86 10.0.17763.0
(that's my version of the windows SDK), I got "The specified configuration type is missing. The tools for the configuration might not be installed".
Do you know what it means ?
Thanks,
Rémi
De : Joaquim Manuel Freire Luís [mailto:jluis at ualg.pt]
Envoyé : lundi 25 février 2019 12:23
À : PROVIN; gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Objet : RE: [gdal-dev] Can't compile GDAL 2.4.0 with Visual 2017 - 32 bits
You are running the nmake command from within a cmd window where you had previously run the vcvarsall.bat for 32 bits, right?
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org<mailto:gdal-dev-bounces at lists.osgeo.org>> On Behalf Of PROVIN
Sent: Monday, February 25, 2019 2:45 PM
To: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Subject: [gdal-dev] Can't compile GDAL 2.4.0 with Visual 2017 - 32 bits
Hello Jeff,
Thank you for your answer, I had tried that already (I usually compile GDAL this way with NMAKE),
but I had the exact same error.
Maybe this has to do with my installation of Visual Studio ?
Remi
Hi Remi,
Personally I'd recommend using the provided nmake.opt inside GDAL's root
directory, and modifying that for your own local libraries. (note that
the cleanest way to do this is to create a new file 'nmake.local' and
put your settings in there, leaving the distributed nmake.opt as
reference only, and then execute that with the command:
nmake /f makefile.vc
(others may recommend using the *.bat magic, but sometimes the raw
commandline is more fun ha)
Have a nice weekend,
-jeff
On 2019-02-21 9:18 AM, PROVIN wrote:
> Hello,
> I am trying to compile GDAL (version 2.40, but I also tried 2.3.1) with
> Visual 2017 in 32 bits.
> I used the generate_vcxproj.bat to generate my Visual project /
> solution, this way (as indicated) :
> generate_vcxproj.bat 15.0 32 gdal_vs2017
> The compilation gives the following error :
> fatal error C1083: Impossible d'ouvrir le fichier include : 'stdio.h' :
> No such file or directory (compilation du fichier source cpl_list.cpp)
> I have this error for all the files cpl_XXXX.cpp of "port" folder.
> It is strange because these files are accessible when I right click on
> the line
> #include <stdio>
> and open the file.
> I tried to retarget the project, tried to reinstall Visual 2017.
> I would be glad if anyone had any advice !
> Thank you,
> REMI
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
[sgn]
Rémi PROVIN
Ingénieur géomatique
854 route de Rémire - 97354 Rémire Montjoly
tél : 05-94-25-61-93 - fax : 05-94-25-61-94
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190225/140eb1ab/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190225/140eb1ab/attachment-0001.png>
