[gdal-dev] grib driver
Zhan Zhang - NOAA Affiliate
zhan.j.zhang at noaa.gov
Thu Feb 28 07:55:00 PST 2019
May I ask whether gdal grib driver support changing grid in a GRIB2
message? For instance, given a GRIB2 message, I want to change from polar
stereographic grid projection to lambert conformal grid projection, and the
data section need also be changed accordingly, and then output this to a
new GRIB2 message. I ask MDL degrib group and they tell me degrib can not
do this. It sound that it is likely gdal grib driver cannot do this either.
However I am not 100% sure and want to seek some comments here. Thanks!
On Thu, Feb 28, 2019 at 10:27 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> On jeudi 28 février 2019 09:29:41 CET Zhan Zhang - NOAA Affiliate wrote:
> > I am new to the gdal apis and is interested in getting some knowledge of
> > the grib driver. May I ask whether it basically provides the same
> > functionality as degrib from MDL/NWS/NOAA? Thanks! --Zhan
> The GDAL GRIB driver strongly relies on degrib+g2clib. It esposes their
> functionality through the general GDAL raster API, so as to be able to
> manipulate a GRIB dataset as any other GDAL raster.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190228/d83e0a72/attachment.html>
