[gdal-dev] vector representation in netcdf 4
Bekaert, David (334H)
David.Bekaert at jpl.nasa.gov
Fri Jan 11 13:22:03 PST 2019
Dear GDAL developers,
I am looking into adding a wkt compatible polygon into a netcdf (version 4) file which also has raster information in it.
Attached is a sample file generated by Even “mixed.nc” with a wkt polygon enclosed formatted as a string of numpy array.
The sample allows to extract a poly using ogr2ogr as “ogr2ogr mixed.shp mixed.nc poly”
Although QGIS does not seem to catch projection information.
Is there a standard way of storing vector information in netcdf conform CF or would the attached sample be specifically for GDAL only?
Thank you,
David
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190111/a81c1193/attachment-0001.html>
Type: application/octet-stream
Desc: mixed.nc
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190111/a81c1193/attachment-0001.obj>
