[gdal-dev] Geoserver/gdal: large tif with multiple overviews - bug + workaround
Idan Miara idan at miara.com
Mon Jan 14 02:51:28 PST 2019
Hi Andrea,
Thanks for very prompt reply and for your suggestions!
I'm wondering if it worth the effort to debug the current gdal-geoserver
plugin.
I remember we talked in FOSS4G about the gdal 2.x support in Geoserver, is
there any progress with that?
I could also reproduce the following bug (
https://osgeo-org.atlassian.net/browse/GEOS-8143) for loading a vrt file
but not for the internal GeoTiff loader.
Kind regards,
Idan
On Mon, 14 Jan 2019 at 12:10, Andrea Aime <andrea.aime at geo-solutions.it>
wrote:
> On Mon, Jan 14, 2019 at 11:01 AM Idan Miara <idan at miara.com> wrote:
>> 2. Is it possible to make Geoserver recognize ovr.ovr files?
> You can contribute changes to the code and add support for ovr.ovr files
> if you want to, see a guide here:
> https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
> If you want to code the improvement yourself just ask, I can give you
> pointers to which classes need to be modified.
>> 3. Can I make geoserver use the gdal plugin for GeoTiff files to avoid
>> the trivial vrt file ?
> We'd have the code, but it has been removed years ago as it was source of
> unpredictable issues when deployed:
> https://osgeo-org.atlassian.net/browse/GEOS-7981
> Again, if you're interested, you could spend time looking at the actual
> source issue and reinstate the plugin.
> Cheers
> Andrea
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf
> Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa
> (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
> http://www.geo-solutions.it http://twitter.com/geosolutions_it
> ------------------------------------------------------- *Con riferimento
> alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
> Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
> circostanza inerente alla presente email (il suo contenuto, gli eventuali
> allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
> destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
> errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
> sarei comunque grato se potesse darmene notizia. This email is intended
> only for the person or entity to which it is addressed and may contain
> information that is privileged, confidential or otherwise protected from
> disclosure. We remind that - as provided by European Regulation 2016/679
> “GDPR” - copying, dissemination or use of this e-mail or the information
> herein by anyone other than the intended recipient is prohibited. If you
> have received this email by mistake, please notify us immediately by
> telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190114/6abc3971/attachment.html>
