[gdal-dev] Geoserver/gdal: large tif with multiple overviews - bug + workaround
Andrea Aime andrea.aime at geo-solutions.it
Mon Jan 14 02:09:59 PST 2019
On Mon, Jan 14, 2019 at 11:01 AM Idan Miara <idan at miara.com> wrote:
> 2. Is it possible to make Geoserver recognize ovr.ovr files?
You can contribute changes to the code and add support for ovr.ovr files if
you want to, see a guide here:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
If you want to code the improvement yourself just ask, I can give you
pointers to which classes need to be modified.
> 3. Can I make geoserver use the gdal plugin for GeoTiff files to avoid the
> trivial vrt file ?
We'd have the code, but it has been removed years ago as it was source of
unpredictable issues when deployed:
https://osgeo-org.atlassian.net/browse/GEOS-7981
Again, if you're interested, you could spend time looking at the actual
source issue and reinstate the plugin.
Cheers
Andrea
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information. == Ing. Andrea Aime @geowolf Technical Lead
GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39
0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
http://www.geo-solutions.it http://twitter.com/geosolutions_it
------------------------------------------------------- *Con riferimento
alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto, gli eventuali
allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
sarei comunque grato se potesse darmene notizia. This email is intended
only for the person or entity to which it is addressed and may contain
information that is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European Regulation 2016/679
“GDPR” - copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If you
have received this email by mistake, please notify us immediately by
telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190114/1706e9f4/attachment.html>
