[gdal-dev] Python/SWIG Build Error
Andrew Bell andrew.bell.ia at gmail.com
Wed Jan 16 19:26:39 PST 2019
Seems the problem is in the python module build. I think I've been here
before 😥
On Wed, Jan 16, 2019, 6:47 PM Andrew Bell <andrew.bell.ia at gmail.com wrote:
> Seems strange that configure would place other directories before the
> location for the current source tree. Is this by design? Is there a way to
> change the behavior?
> On Wed, Jan 16, 2019, 6:22 PM Even Rouault <even.rouault at spatialys.com
> wrote:
>> On mercredi 16 janvier 2019 17:41:26 CET Andrew Bell wrote:
>> > I'm trying to build GDAL master branch with the python wrappers and I'm
>> > getting an error on OSX with clang:
>> > creating build/temp.macosx-10.7-x86_64-3.6
>> > creating build/temp.macosx-10.7-x86_64-3.6/extensions
>> > gcc -Wno-unused-result -Wsign-compare -Wunreachable-code -DNDEBUG -g
>> > -fwrapv -O3 -Wall -Wstrict-prototypes
>> > -I/Users/acbell/miniconda2/envs/pdal/include
>> > -Wno-error=unused-command-line-argument-hard-error-in-future
>> -I../../port
>> > -I../../gcore -I../../alg -I../../ogr/ -I../../ogr/ogrsf_frmts
>> -I../../gnm
>> > -I../../apps -I/Users/acbell/miniconda2/envs/pdal/include/python3.6m
>> -I/Users/acbell/miniconda2/envs/pdal/lib/python3.6/site-packages/numpy/core/
>> > include -I/Users/acbell/gdal/gdal/include -c extensions/gdal_wrap.cpp -o
>> > build/temp.macosx-10.7-x86_64-3.6/extensions/gdal_wrap.o -std=c++11
>> > -I/Users/acbell/gdal/gdal/port -I/Users/acbell/gdal/gdal/gcore
>> > -I/Users/acbell/gdal/gdal/alg -I/Users/acbell/gdal/gdal/ogr
>> > -I/Users/acbell/gdal/gdal/ogr/ogrsf_frmts
>> > -I/Users/acbell/gdal/gdal/frmts/vrt -I/Users/acbell/gdal/gdal/apps
>> > extensions/gdal_wrap.cpp:4087:1: error: unknown type name 'VSIDIR'
>> > VSIDIR* wrapper_VSIOpenDir( const char * utf8_path,
>> > extensions/gdal_wrap.cpp:4091:12: error: use of undeclared identifier
>> >       'VSIOpenDir'
>> >     return VSIOpenDir(utf8_path, nRecurseDepth, options);
>> > extensions/gdal_wrap.cpp:4135:38: error: unknown type name 'VSIDIR'
>> > DirEntry* wrapper_VSIGetNextDirEntry(VSIDIR* dir)
>> > extensions/gdal_wrap.cpp:4137:11: error: unknown type name 'VSIDIREntry'
>> >     const VSIDIREntry* vsiEntry = VSIGetNextDirEntry(dir);
>> It smells like you'd have cpl_xxxx.h files from older GDAL versions in
>> your
>> include paths.
>> /Users/acbell/miniconda2/envs/pdal/include might be a candidate for
>> examination.
>> Even
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190116/8196a235/attachment.html>
