[gdal-dev] ogr not reading the prj file
TUELLER, SHAYNE R CIV USAF AFMC 519 SMXS/MXDEC
shayne.tueller at us.af.mil
Fri Jan 18 15:44:48 PST 2019
Hello,
I'm using gdal 2.3.1 that I built from source. I run the following command to inspect the contents of a shapefile...
ogrinfo -al circles.shp
When I run this command on the shapefile, I get the SRS information "Layer SRS_WKT" reporting from what is found in the "data" folder and not the SRS information defined in the circles.prj file.
What do I need to do to get the SRS information in the circles.prj file instead? I'm assuming my built library is missing the PROJ4 library?
Thanks.
Shayne
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190118/8511e4a2/attachment.html>
