[gdal-dev] ogr not reading the prj file
TUELLER, SHAYNE R CIV USAF AFMC 519 SMXS/MXDEC
shayne.tueller at us.af.mil
Tue Jan 22 09:43:48 PST 2019
Yes, that is correct. So, I guess it is working as designed with the newer version of gdal?
Is there any way of forcing it to use the SRS info in my prj file with this newer version or am I stuck?
Shayne
ok, so I guess ogrinfo -al -so reports
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4326"]]
This is the expected behaviour. The content of a .prj file is WKT with the ESRI variant formatting. Newer GDAL versions manage to retrieve the OGC WKT definition when the ESRI WKT corresponds to a EPSG code.
Spatialys - Geospatial professional services http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190122/2d043991/attachment.html>
