[gdal-dev] Perforce issue in coordinate transformations with Gdal 2.3.2
Stefan Moebius Stefan.Moebius at amdocs.com
Mon Jan 28 07:44:19 PST 2019
As we do lots of coordinate transformations in our (Java based) product, we
have the performance test below in our code base. We recently tried to
upgrade from Gdal 1.9 to 2.3.2, and suddenly our coordinate transformation
tests failed, because they took about twice the time as before.
Should we be calling anything differently when using Gdal 2.x?
Anything else we do wrong?
What could be the problem here?
Regards,
Stefan
The code (extracted from our code base, tested with Java 8 and Junit 4):
import java.util.ArrayList;
import java.util.Collections;
import java.util.List;
import java.util.Random;
import java.util.stream.Collectors;
import java.util.stream.Stream;
import org.gdal.osr.SpatialReference;
public class CoordinateTransformationTest
	public CoordinateTransformationTest() {}
	static class SpatialCoordinate
	    public final double northing; /// latitude  or northing in
meters
	    public final double easting;  /// longitude or easting in meters
	    public SpatialCoordinate(double northing, double easting)
	        this.northing = northing;
	        this.easting = easting;
	    @Override
	    public boolean equals(Object obj)
	        if (this == obj)  return  true;
	        if (!(obj instanceof SpatialCoordinate))  return  false;
	        SpatialCoordinate  other = (SpatialCoordinate) obj;
	        return (easting == other.easting) && (northing ==
other.northing);
	    @Override
	    public int hashCode()
	        return Double.valueOf(northing).hashCode() ^
Integer.rotateLeft(Double.valueOf(easting).hashCode(), 16);
    static class CoordinateTransformation
        private /*final*/ org.gdal.osr.CoordinateTransformation
coordinateTransformation;
        private CoordinateTransformation(SpatialReference source,
SpatialReference target)
            this.coordinateTransformation = new
org.gdal.osr.CoordinateTransformation(source, target);
        public synchronized SpatialCoordinate transform(SpatialCoordinate
from)
            // the JNI interface expects a 3d array!
            double[] coordinates3D = { from.easting, from.northing, 0.0 };
            coordinateTransformation.TransformPoint(coordinates3D);
            return new SpatialCoordinate(coordinates3D[1],
coordinates3D[0]);
        public List<SpatialCoordinate> transform(List<SpatialCoordinate>
coordinates)
            if (coordinates.isEmpty())
                return Collections.emptyList();
            double[][] eastNorth = new double[coordinates.size()][2];
            for (int i = 0; i < coordinates.size(); i++)
                final SpatialCoordinate coord = coordinates.get(i);
                eastNorth[i][0] = coord.easting;
                eastNorth[i][1] = coord.northing;
            transform(eastNorth);
            final List<SpatialCoordinate> result = new
ArrayList<>(coordinates.size());
                result.add(new SpatialCoordinate(eastNorth[i][1],
eastNorth[i][0]));
            return result;
        private synchronized void transform(double[][] coordinates)
            assert (coordinates != null && coordinates.length > 0 &&
coordinates[0] != null && coordinates[0].length >= 2);
            coordinateTransformation.TransformPoints(coordinates);
    static SpatialReference wgs84UtmNorth(final int utm)
        final int epsg = 32600 + utm;
        final int meridian = -177 + 6 * (utm - 1);
        final String wkt = String
                .format(
                        "PROJCS[\"WGS 84 / UTM zone %dN\",GEOGCS[\"WGS
84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS
84\",6378137,298.257223563,AUTHORITY[\"EPSG\",\"7030\"]],AUTHORITY[\"EPSG\",
\"6326\"]],PRIMEM[\"Greenwich\",0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"degre
e\",0.01745329251994328,AUTHORITY[\"EPSG\",\"9122\"]],AUTHORITY[\"EPSG\",\"4
326\"]],PROJECTION[\"Transverse_Mercator\"],PARAMETER[\"latitude_of_origin\"
,0],PARAMETER[\"central_meridian\",%d],PARAMETER[\"scale_factor\",0.9996],PA
RAMETER[\"false_easting\",500000],PARAMETER[\"false_northing\",0],UNIT[\"met
re\",1,AUTHORITY[\"EPSG\",\"9001\"]],AXIS[\"Easting\",EAST],AXIS[\"Northing\
",NORTH],AUTHORITY[\"EPSG\",\"%d\"]]",
                        utm, meridian, epsg);
        return new SpatialReference(wkt);
    static SpatialReference wgs84()
    	return new SpatialReference("GEOGCS[\"WGS
326\"]]");
    static SpatialReference dhdn3()
    	return new SpatialReference("PROJCS[\"DHDN / 3-degree Gauss zone 2
(deprecated)\",GEOGCS[\"DHDN\",DATUM[\"Deutsches_Hauptdreiecksnetz\",SPHEROI
D[\"Bessel
1841\",6377397.155,299.1528128,AUTHORITY[\"EPSG\",\"7004\"]],AUTHORITY[\"EPS
G\",\"6314\"]],PRIMEM[\"Greenwich\",0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"d
egree\",0.01745329251994328,AUTHORITY[\"EPSG\",\"9122\"]],AUTHORITY[\"EPSG\"
,\"4314\"]],PROJECTION[\"Transverse_Mercator\"],PARAMETER[\"latitude_of_orig
in\",0],PARAMETER[\"central_meridian\",6],PARAMETER[\"scale_factor\",1],PARA
METER[\"false_easting\",2500000],PARAMETER[\"false_northing\",0],UNIT[\"metr
e\",1,AUTHORITY[\"EPSG\",\"9001\"]],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH],AUTHO
RITY[\"EPSG\",\"31462\"]]");
    static void testBulkSpeed(
            SpatialReference target,
            SpatialCoordinate center,
            double epsilon)
        final CoordinateTransformation ct = new
        final Random rand = new Random();
        final int size = 1024;
        for (int i = 0; i < size; ++i)
            final List<SpatialCoordinate> coords = Stream //
                    .generate(() -> new SpatialCoordinate(center.northing +
(rand.nextDouble() * 2 - 1) * epsilon, //
                                                          center.easting +
(rand.nextDouble() * 2 - 1) * epsilon)) //
                    .limit(size) //
                    .collect(Collectors.toList());
            @SuppressWarnings("unused")
            List<SpatialCoordinate> results = ct.transform(coords);
    @org.junit.Test(timeout=1000)
    public void testGeogToProjBulkSpeed()
    	SpatialReference utm30 = wgs84UtmNorth(30);
    	SpatialReference wgs84 = wgs84();
        testBulkSpeed(wgs84, utm30, new SpatialCoordinate(40.0, -3.0), 360.0
/ 40000000.0);
    @org.junit.Test(timeout=1500)
    public void testProjToGeogBulkSpeed()
        testBulkSpeed(utm30, wgs84, new SpatialCoordinate(0.0, 0.0), 1.0);
    @org.junit.Test(timeout=2000)
    public void testProjToProjBulkSpeed()
    	SpatialReference utm31 = wgs84UtmNorth(31);
        testBulkSpeed(utm30, utm31, new SpatialCoordinate(0.0, 0.0), 1.0);
    @org.junit.Test(timeout=3000)
    public void testProjToProjViaToWgs84BulkSpeed()
    	SpatialReference utm32 = wgs84UtmNorth(32);
    	SpatialReference dhdn3 = dhdn3();
        testBulkSpeed(utm32, dhdn3, new SpatialCoordinate(0.0, 0.0), 1.0);
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190128/4f643e3b/attachment-0001.bin>
This email and the information contained herein is proprietary and confidential and subject to the Amdocs Email Terms of Service, which you may review at https://www.amdocs.com/about/email-terms-of-service <https://www.amdocs.com/about/email-terms-of-service>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190128/4f643e3b/attachment-0001.html>
