[gdal-dev] UnionCascaded operation failed
Casper Børgesen caboe at sdfe.dk
Mon Jul 1 02:15:35 PDT 2019
Hi Ahmet
I haven’t visited C++ and ogr for quite some time, but I think you should define and initialize polyCollect like this:
OGRMultiPolygon *polyCollect = new OGRMultiPolygon();
This type should implement the UnionCascaded() method.
Maybe other users on the list can chime in?
/Casper
Sent: 1. juli 2019 09:04
To: Casper Børgesen <caboe at sdfe.dk>
Subject: Re: [gdal-dev] UnionCascaded operation failed
It is geometry list indeed as:
 std::vector<OGRPolygon * > polyCollect ;
I converted it to OGRMultiPolygon
But
 OGRGeometry *result=polyCollect.UnionCascaded();  // ???
still failed
On Mon, Jul 1, 2019 at 8:55 AM Ahmet Temiz <ahmettemiz88 at gmail.com<mailto:ahmettemiz88 at gmail.com>> wrote:
Ok, thanks.
On Mon, Jul 1, 2019 at 8:39 AM Casper Børgesen <caboe at sdfe.dk<mailto:caboe at sdfe.dk>> wrote:
A very quick guess would be that you have changed the polyCollect type from a geometry type to a list of geometries. I don’t think the list of geometries has a UnionCascaded method. I would probably go for a polyCollect geometry type of MultiPolygon instead of the list/vector, that way you should be able to run the UnionCascaded method.
/Casper
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org<mailto:gdal-dev-bounces at lists.osgeo.org>> On Behalf Of Ahmet Temiz
Sent: 29. juni 2019 19:47
To: gdal-dev <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>>
Subject: [gdal-dev] UnionCascaded operation failed
Using C++ I try to buffers from LineStrings,Then I want to union the
resulting polygons with UnionCascaded.
But at UnionCascaded operation failed with:
"error: ‘class std::vector<OGRPolygon*>’ has no member named ‘UnionCascaded’
Can you tell me what I am doing wrong?
here is the related code fragment:
    //OGRGeometryCollection *polyCollect ;
    while( (poFeature = poLayer->GetNextFeature()) != NULL )
        OGRGeometry *poGeometry = poFeature->GetGeometryRef();
        if( poGeometry != NULL
                && wkbFlatten(poGeometry->getGeometryType()) == wkbLineString )
            OGRLineString *poLine = (OGRLineString *) poGeometry;
            OGRGeometry *bufGeometry = poLine->Buffer(100,30);
   OGRPolygon *bufPoly=  static_cast<OGRPolygon *> (bufGeometry) ;
            printf( "%s \n", bufPoly->getGeometryName());
   //polyCollect->addGeometryDirectly (bufPoly );
            polyCollect.push_back(bufPoly );
        else
            printf( "no point geometry\n" );
        OGRFeature::DestroyFeature( poFeature );
Ahmet Temiz
Jeoloji Müh.
Afet ve Acil Durum Yönetimi Başkanlığı
Bilgi İşlem  Dairesi Başkanlığı-CBS Grubu
________________________
Ahmet Temiz
Geological Eng.
Information Systems - GIS Group
Disaster and Emergency Management
of Presidency
Ahmet Temiz
Jeoloji Müh.
Ahmet Temiz
Geological Eng.
of Presidency
Ahmet Temiz
Jeoloji Müh.
Ahmet Temiz
Geological Eng.
of Presidency
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190701/68f3393d/attachment.html>
