[gdal-dev] 2.4 problem with OGRCoordinateTransformation?
Even Rouault
even.rouault at spatialys.com
Mon Jul 15 08:41:07 PDT 2019
On lundi 15 juillet 2019 11:33:40 CEST Andrew Bell wrote:
> I'm seeing an issue with OGRCoordinateTransformation where the first point
> passed to the transform is handled properly, but the second one is not.
> I'm just seeing this on version 2.4. Earlier versions are OK, as is 3.0
> with identical code. I don't know where the old tickets are, so I'm
> wondering if anyone was aware of an issue that might have been fixed after
> 2.4.
Andrew,
Are you really sure about that ? I can't see related differences in
ogr/ogrct.cpp between 2.3 and 2.4 that would have that effect.
Even
http://www.spatialys.com
