[gdal-dev] 2.4 problem with OGRCoordinateTransformation?
Andrew Bell andrew.bell.ia at gmail.com
Mon Jul 15 08:45:00 PDT 2019
On Mon, Jul 15, 2019 at 11:41 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> On lundi 15 juillet 2019 11:33:40 CEST Andrew Bell wrote:
> > I'm seeing an issue with OGRCoordinateTransformation where the first
> point
> > passed to the transform is handled properly, but the second one is not.
> > I'm just seeing this on version 2.4.  Earlier versions are OK, as is 3.0
> > with identical code.  I don't know where the old tickets are, so I'm
> > wondering if anyone was aware of an issue that might have been fixed
> after
> > 2.4.
> Andrew,
> Are you really sure about that ? I can't see related differences in
> ogr/ogrct.cpp between 2.3 and 2.4 that would have that effect.
I only know what's happening.  I was just trying to check if anyone
remembered an issue.  I'll trace things through.
Thanks,
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190715/5f71772e/attachment.html>
