[gdal-dev] vsicurl access to a netcdf file does not see the coordinates
Andrew C Aitchison
andrew at aitchison.me.uk
Sun Jun 2 06:35:06 PDT 2019
On Sun, 2 Jun 2019, Jeff McKenna wrote:
> On 2019-06-01 6:52 PM, Joaquim Manuel Freire Lu?s wrote:
>> Is there a way to force reading the grid locally with the HDF5 driver
>> instead of the automatically picked netCDF driver?
> I come across this need often also, as many MS4W users leverage GDAL through
> netCDF, HDF5, HDF4, but I'm not aware of a GDAL commandline option to 'skip'
> raster drivers (OGR has "OGR_SKIP"). I could be wrong though. I have seen
> other users request this (https://trac.osgeo.org/gdal/ticket/5917) which
> seems to say that there is a way through the GDAL API, but, I'm just not sure
> about the commandline.
Rather like OGR_SKIP, the GDAL_SKIP environment variable skips raster
drivers (tested with gdal 1.11 and 3.0.)
Andrew C. Aitchison Cambridge, UK
