[gdal-dev] Getting database is locked error when writing to GeoPackage database.
Even Rouault
even.rouault at spatialys.com
Wed Jun 5 05:47:25 PDT 2019
On mercredi 5 juin 2019 05:38:32 CEST jkellio2 wrote:
> I'm using the OGR/GDAL C# managaged API to write to a GeoPackage database
> and I keep running into a "database is locked" error when I try to sync the
> database to disk. After much experimentation, this appears to only happen
> if I first open the GeoPackage to do a read, close the db (Dispose the
> DataSource), reopen db and attempt to write. Web searches indicate that
> this error occurs if the GDAL and SQLite objects from the read are not
> disposed before attempting the write. However, I think I'm disposing all
> the managed objects properly so I'm wondering if there is a call that I'm
> missing.
I'm pretty ignorant of C#, but I believe you may need to explicitly call the
SWIG generated Dispose() method on the DataSource object. Pure C# garbage
collection is probably not always sufficient.
Even
http://www.spatialys.com
