[gdal-dev] Inserting PDF image to geoPDF
Jane Wang jane at fybr.ca
Tue Jun 11 09:40:22 PDT 2019
Dear gdal-dev team,
I am attempting to insert a (non-georeferenced) PDF image containing map
legend and company logo using -co EXTRA_IMAGES=legend.pdf for my
gdal_translate -of PDF command.
However, in my output geoPDF document, the legend.pdf image has been
rasterised which is not desired. I wonder if there is a work-around for
this, or if I am not doing it correctly?
I am able to output the legend containing some text and geometric shapes
into other vector formats. i.e. .svg but it did not make a difference on
the map output.
Thank you very much, please let me know if I can provide additional
information / documents.
Regards,
Jane
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190611/9f203e49/attachment.html>
