[gdal-dev] Convert WGS84 geodetic coordinate to local ENU(local Cartesian coordinates coordinate system)
Changhai Chen cchhnhk at gmail.com
Tue Jun 11 20:42:12 PDT 2019
Hello. Is there any method in GDAL that can convert WGS84 geodetic
coordinate to local ENU(local tangent plane)?
First: GDAL can transform point coordinate from WGS84 geodetic  coordinate
system to WGS84 XYZ (or ECEF ).
Second: but WGS84 XYZ (or ECEF ) to local ENU can not be transformed. I can
fix it by using another tool, but it will be better if GDAL have this
convesion.
Thanks.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190612/af7e4531/attachment.html>
