[gdal-dev] Ellipsoidal length of a line
Atle Frenvik Sveen atle at frenviksveen.net
Fri Jun 14 09:19:02 PDT 2019
Hi!
Not sure if would want to use gdal for this task*, but take a look at this blog post:
https://janakiev.com/blog/gps-points-distance-python/
*or if it's doable, i guess not, since the scope of gdal is reading/writing geospatial formats
-a
  Atle Frenvik Sveen
  45278689
  atlefren.net
On Fri, Jun 14, 2019, at 17:32, Nicolas Cadieux wrote:
> Hi,
> I am trying to get the length of a line in python. (Not just the
> straight length between the first and last nodes).  Using geopandas,
> (therefore the Shapely lib) I am getting the euclidien distance even
> though the dataframe holdings the line geometries has a CRS (WGS84,
> zone UTM 18 S).  Obviously, the WGS84 Ellipsoid is not taken into
> account.
> Can I do this with gdal/ogr?
> Thanks for the help
> Nicolas
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
