[gdal-dev] Ellipsoidal length of a line
Patrick Young
patrick.mckendree.young at gmail.com
Fri Jun 14 10:20:20 PDT 2019
Not exactly what you want, but you can do this with PostGIS by casting your
geometry to the geography type:
https://postgis.net/workshops/postgis-intro/geography.html
On Fri, Jun 14, 2019 at 10:26 AM Atle Frenvik Sveen <atle at frenviksveen.net>
wrote:
> Hi!
> Not sure if would want to use gdal for this task*, but take a look at this
> blog post:
> https://janakiev.com/blog/gps-points-distance-python/
> *or if it's doable, i guess not, since the scope of gdal is
> reading/writing geospatial formats
> -a
> Atle Frenvik Sveen
> 45278689
> atlefren.net
> On Fri, Jun 14, 2019, at 17:32, Nicolas Cadieux wrote:
> > Hi,
> > I am trying to get the length of a line in python. (Not just the
> > straight length between the first and last nodes). Using geopandas,
> > (therefore the Shapely lib) I am getting the euclidien distance even
> > though the dataframe holdings the line geometries has a CRS (WGS84,
> > zone UTM 18 S). Obviously, the WGS84 Ellipsoid is not taken into
> > account.
> > Can I do this with gdal/ogr?
> > Thanks for the help
> > Nicolas
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190614/3e5db5bb/attachment.html>
