[gdal-dev] Ellipsoidal length of a line
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Fri Jun 14 21:42:35 PDT 2019
Thanks,
Could work but I think this will be too slow. I wonder how QGIS does it? I guess they use code from Proj.4.  If anyone has an other idea, shoot!
Cheers
Nicolas
> Le 14 juin 2019 à 13:20, Patrick Young <patrick.mckendree.young at gmail.com> a écrit :
> Not exactly what you want, but you can do this with PostGIS by casting your geometry to the geography type:
> https://postgis.net/workshops/postgis-intro/geography.html
>> On Fri, Jun 14, 2019 at 10:26 AM Atle Frenvik Sveen <atle at frenviksveen.net> wrote:
>> Hi!
>> Not sure if would want to use gdal for this task*, but take a look at this blog post:
>> https://janakiev.com/blog/gps-points-distance-python/
>> *or if it's doable, i guess not, since the scope of gdal is reading/writing geospatial formats
>> -a
>>   Atle Frenvik Sveen
>>   45278689
>>   atlefren.net
>> On Fri, Jun 14, 2019, at 17:32, Nicolas Cadieux wrote:
>> > Hi,
>> > I am trying to get the length of a line in python. (Not just the
>> > straight length between the first and last nodes).  Using geopandas,
>> > (therefore the Shapely lib) I am getting the euclidien distance even
>> > though the dataframe holdings the line geometries has a CRS (WGS84,
>> > zone UTM 18 S).  Obviously, the WGS84 Ellipsoid is not taken into
>> > account.
>> > Can I do this with gdal/ogr?
>> > Thanks for the help
>> > Nicolas
>> > _______________________________________________
>> > gdal-dev mailing list
>> > gdal-dev at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190615/d1403b43/attachment.html>
