[gdal-dev] Stuck with python gdal.Grid throwing an error
Even Rouault even.rouault at spatialys.com
Sat Jun 15 00:53:24 PDT 2019
>          err = gdal.Grid(dataset, ds, options=opts)
>          if err != 0:
>              print 'gdalGrid error: ', err
>              return
> The above code is basically the same as what I use for
> gdal.RasterizeLayer() and that worked fine.
gdal.Grid() prototype is
def Grid(destName, srcDS, **kwargs):
    """ Create raster from the scattered data.
        Arguments are :
          destName --- Output dataset name
          srcDS --- a Dataset object or a filename
        Keyword arguments are :
          options --- return of gdal.GridOptions(), string or array of strings
          other keywords arguments of gdal.GridOptions()
        If options is provided as a gdal.GridOptions() object, other keywords
are ignored. """
So the first argument must be a filename, not a dataset. Only a few utilities
accept updating an existing dataset. gdal.Grid() will generate a new output
dataset.
Even
http://www.spatialys.com
