[gdal-dev] Failure to convert to Airy
Even Rouault even.rouault at spatialys.com
Mon Jun 17 10:00:05 PDT 2019
> used to work before the GDAL3+PROJ6 combo.
That would be surprising: with GDAL 2.4 and PROJ < 6, you also get an error,
but with a different message:
$ gdalinfo --version
GDAL 2.4.1, released 2019/03/15
$ echo 4.897 52.371 | \
	gdaltransform -s_srs +proj=longlat -t_srs "+proj=airy +wktext"
ERROR 6: Failed to initialize PROJ pipeline from `+proj=airy +wktext' to `
+proj=longlat +ellps=WGS84 +no_defs': malformed pipeline
328249.00331295 4987937.10144727 0
http://www.spatialys.com
