[gdal-dev] Failure to convert to Airy
Joaquim Manuel Freire Luís
jluis at ualg.pt
Mon Jun 17 10:14:21 PDT 2019
Well, I call it via GMT but that test is in GMT for a while and it used to pass.
Anyway, I'll have to investigate this further because I rebuilt GDAL and now the gdaltransform works, but when I call it from GMT is still fails.
The code is
https://github.com/GenericMappingTools/gmt/blob/master/src/gmt_ogrproj.c#L27
and a quick debug shows that the failure occurs the second time that function is called. For some reason that I don't remember right now, I have to call it twice.
(I've to go now for > 1 hour, so won't be able to reply in case of)
|>-----Original Message-----
|>From: Even Rouault <even.rouault at spatialys.com>
|>Sent: Monday, June 17, 2019 6:00 PM
|>To: Joaquim Manuel Freire Luís <jluis at ualg.pt>
|>Cc: gdal-dev at lists.osgeo.org
|>Subject: Re: [gdal-dev] Failure to convert to Airy
|>> used to work before the GDAL3+PROJ6 combo.
|>That would be surprising: with GDAL 2.4 and PROJ < 6, you also get an error,
|>but with a different message:
|>$ gdalinfo --version
|>GDAL 2.4.1, released 2019/03/15
|>$ echo 4.897 52.371 | \
|> gdaltransform -s_srs +proj=longlat -t_srs "+proj=airy +wktext"
|>ERROR 6: Failed to initialize PROJ pipeline from `+proj=airy +wktext' to `
|>+proj=longlat +ellps=WGS84 +no_defs': malformed pipeline
|>328249.00331295 4987937.10144727 0
|>Spatialys - Geospatial professional services http://www.spatialys.com
