[gdal-dev] ogr2ogr MVT use of CONF parameter
Even Rouault
even.rouault at spatialys.com
Wed Jun 19 03:25:44 PDT 2019
> ogr2ogr -F MVT test6.mbtiles 8-0.0-55.0.sqlite -dsco CONF=conf.json -dsco
> FORMAT=MBTILES
Actually currently, the CONF option only accepts a JSon string, not a
filename.
So currently, you should provide inline, with proper escaping.
Something like that (but not completely sure of escaping rules in windows
shells)
-dsco CONF="{ \"poly\": { \"target_name\": \"mypoly\" } }"
That said, I've just added support for accepting a filename as well (in master
and backported to 3.0 branch), since that is completely reasonable as an
expectation.
Even
http://www.spatialys.com
