[gdal-dev] ogr2ogr MVT use of CONF parameter
Giorgio Ghiggini gghiggini at gec-it.com
Wed Jun 19 05:41:09 PDT 2019
thanks a lot
-----Original Message-----
Sent: mercoledì 19 giugno 2019 12:26
To: gdal-dev at lists.osgeo.org
Cc: Giorgio Ghiggini <gghiggini at gec-it.com>
Subject: Re: [gdal-dev] ogr2ogr MVT use of CONF parameter
> ogr2ogr -F MVT test6.mbtiles 8-0.0-55.0.sqlite -dsco CONF=conf.json
> -dsco FORMAT=MBTILES
Actually currently, the CONF option only accepts a JSon string, not a
filename.
So currently, you should provide inline, with proper escaping.
Something like that (but not completely sure of escaping rules in windows
shells)
-dsco CONF="{ \"poly\": { \"target_name\": \"mypoly\" } }"
That said, I've just added support for accepting a filename as well (in
master and backported to 3.0 branch), since that is completely reasonable as
an expectation.
Even
Spatialys - Geospatial professional services http://www.spatialys.com
