[gdal-dev] kml file with line length too long
Even Rouault
even.rouault at spatialys.com
Thu Jun 27 14:34:28 PDT 2019
> ERROR 1: Failed to create file lolo.shp\RGT 2 DOY-179 28-Jun-2019
> 04:55:18.shp: No error
Ah, I see. There are ':' characters in the layername, which are invalid
characters for a filename on Windows. As I tested the gisinternals builds on
Wine, this limitation is probably not emulated
Anyway, I've just pushed code in the shapefile driver to launder layer name to
get valid filenames. Ah shapefiles...
Even
http://www.spatialys.com
