[gdal-dev] kml file with line length too long
Joaquim Manuel Freire Luís jluis at ualg.pt
Thu Jun 27 14:38:49 PDT 2019
Thanks. I'll try it.
|>-----Original Message-----
|>From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Even Rouault
|>Sent: Thursday, June 27, 2019 10:34 PM
|>To: gdal-dev at lists.osgeo.org
|>Cc: jratike80 <jukka.rahkonen at maanmittauslaitos.fi>
|>Subject: Re: [gdal-dev] kml file with line length too long
|>> ERROR 1: Failed to create file lolo.shp\RGT 2 DOY-179 28-Jun-2019
|>> 04:55:18.shp: No error
|>Ah, I see. There are ':' characters in the layername, which are invalid characters
|>for a filename on Windows. As I tested the gisinternals builds on Wine, this
|>limitation is probably not emulated Anyway, I've just pushed code in the
|>shapefile driver to launder layer name to get valid filenames. Ah shapefiles...
|>Even
|>Spatialys - Geospatial professional services http://www.spatialys.com
|>_______________________________________________
|>gdal-dev mailing list
|>https://lists.osgeo.org/mailman/listinfo/gdal-dev
