[gdal-dev] GDAL VRT with Cloud Optimized GeoTIFFs and AWS
Michael Smith
michael.smith.erdc at gmail.com
Mon Mar 4 06:24:08 PST 2019
There are multiple advantages to using s3 over ebs. First is availability. S3 is highly available (and replicated). EBS is limited to the single volume and is much more fragile. EBS is also more expensive for storage than S3. And S3 is available to multiple instances, EBS is not, it can only be mounted to one EC2 instance.
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Richard Greenwood <richard.greenwood at gmail.com>
Date: Monday, March 4, 2019 at 9:21 AM
To: Jeremy Palmer <palmerjnz at gmail.com>
Cc: gdal dev <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] GDAL VRT with Cloud Optimized GeoTIFFs and AWS
What are the advantages of storing the imagery in S3 as opposed to EBS? I'm using the throughput optimized magnetic EBS which I is a little less expensive than S3. I did some testing a couple years ago and didn't see enough performance gain to justify SSD. Have you tested S3 against any of the EBS options?
Rich
On Sat, Mar 2, 2019 at 7:58 AM Jeremy Palmer <palmerjnz at gmail.com> wrote:
I've now found this useful Mapserver wiki page https://github.com/mapserver/mapserver/wiki/Render-images-straight-out-of-S3-with-the-vsicurl-driver. It seems to imply that it's better to merge a collection of dataset tiles into a single big Geotiff rather than create a VRT due to the repeated HTTP calls. I'm still interested in people's experiences using imagery direct from S3 and it's performance.
Note some of my largest datasets have a total size of 1.5TBs uncompressed Geotiff with about 8000 tiles @ 175mb per tile. I'll likely compress the uncompressed Geotiffs and use JPEG compression, which I estimate can bring the size down to about 200GB total.
Cheers
Jeremy
On Sat, Mar 2, 2019 at 9:15 AM Jeremy Palmer <palmerjnz at gmail.com> wrote:
Hi All,
Does anyone have any tips or experience in trying to serve RGB large imagery multi file datasets hosted on S3 to application servers/containers for bulk tile rendering? Is this possible using VRTs and is the performance manageable when compared to other mounted storage options?
Thanks,
Jeremy
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
Richard W. Greenwood, PLS
www.greenwoodmap.com
_______________________________________________ gdal-dev mailing list gdal-dev at lists.osgeo.org https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190304/4edc402d/attachment.html>
