[gdal-dev] NOAA satellite swath NetCDF file to georeferenced Gtiff?
Rutger kassies at gmail.com
Wed Mar 6 01:01:57 PST 2019
Hey,
For as far as i know, the geolocation with GDAL only works for regular
(rectilinear?) grids. Swaths of scanning sensors (like MODIS/VIIRS etc) are
often irregular because of the bow-tie or other effects.
Have a look at Satpy or Pyresample (which Satpy uses) to handle those more
complex cases. It supports a lot of sensors out of the box, but it's also
quite easy to make a custom reader if you have to:
https://satpy.readthedocs.io/en/latest/#id1
<https://satpy.readthedocs.io/en/latest/#id1>
Regards,
Rutger
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
