[gdal-dev] NOAA satellite swath NetCDF file to georeferenced Gtiff?
Markus Neteler
neteler at osgeo.org
Wed Mar 6 05:32:59 PST 2019
maybe Pytroll could also be of interest.
See e.g.
https://pytroll.readthedocs.io/en/latest/quickstart_avhrr.html
https://pytroll.readthedocs.io/en/latest/quickstart_viirs.html
Markus
On Wed, Mar 6, 2019 at 10:02 AM Rutger <kassies at gmail.com> wrote:
> Hey,
> For as far as i know, the geolocation with GDAL only works for regular
> (rectilinear?) grids. Swaths of scanning sensors (like MODIS/VIIRS etc)
are
> often irregular because of the bow-tie or other effects.
> Have a look at Satpy or Pyresample (which Satpy uses) to handle those more
> complex cases. It supports a lot of sensors out of the box, but it's also
> quite easy to make a custom reader if you have to:
> https://satpy.readthedocs.io/en/latest/#id1
> <https://satpy.readthedocs.io/en/latest/#id1>
> Regards,
> Rutger
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190306/686c567a/attachment.html>
