[gdal-dev] gdal and proj
Sebastiaan Couwenberg
sebastic at xs4all.nl
Fri Mar 8 05:26:20 PST 2019
On 3/8/19 2:11 PM, Greg Troxel wrote:
> But, I can't see where proj is actually linked. configure seems to
> simply declare that it will be dynamic if there is no explicit request
> to use the version 4 API. I don't see it linked into ligdal.so, or
> ogr2ogr, or any other file that is produced. I don't find HAVE_PROJ in
> makefiles to add -lproj.
Looks like you don't use the --with-static-proj4 configure option which
was renamed to --with-proj in 2.3.0.
Kind regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
