[gdal-dev] GDAL.Net 2.3.1 - CoordinateTransformation mismatch....
Morten Breiner morten at breiner.dk
Sun Mar 10 15:24:55 PDT 2019
I hope that I am posting my question to the right mailing list.
Currently, I am investigating the use of GDAL.NET 2.3.1 installed as a
NUGET package in VisualStudio 2017.
It works very well when it comes to reading geotiff using provided
drivers etc. However, when it comes to performing a coordinate
transformation from one geodesy to another I encounter a mismatch
between actual and expected coordinates. I have illustrated this in the
Test Method below, where I have tried to transform a coordinate from
EPSG:32028 to EPSG:4326, my test fails the final two Asserts.AreEqual
when testing "x" and "y".
[TestMethod]
publicvoidGdalTransformEPSG32028ToEPSG4326()
// Setting environment variables and load all GDAL and OGR drivers
GdalConfiguration.ConfigureGdal();
GdalConfiguration.ConfigureOgr();
stringverInfo = Gdal.VersionInfo(string.Empty);
Assert.IsTrue(String.Compare(verInfo, "GDAL 2.3.1, released 2018/06/22",
StringComparison.Ordinal)==0);
SpatialReference spatialSrc = newSpatialReference(string.Empty);
spatialSrc.ImportFromEPSG(32028);
SpatialReference spatialDest = newSpatialReference(string.Empty);
spatialDest.ImportFromEPSG(4326);
CoordinateTransformation transformator =
newCoordinateTransformation(spatialSrc, spatialDest);
double[] result = newdouble[3];
transformator.TransformPoint(result, 2397350, 386280, 0);
// Actual output:  x=-76.3056550480934,  y=41.2177849636383,  z=0.0
// EPSG.io output: x=-76.3053142,        y=41.217868
Assert.AreEqual(-76.3053142, result[0], 1e-6, "x"); // failure
x=-76.3056550480934
Assert.AreEqual(41.217868, result[1], 1e-6, "y"); // failure y=
41.2177849636383
The static method GdalConfiguration() configure paths for proj lib,
drivers etc as illustrated below:
///<summary>
///Construction of Gdal/Ogr
///</summary>
staticGdalConfiguration()
varexecutingAssemblyFile =
newUri(Assembly.GetExecutingAssembly().GetName().CodeBase).LocalPath;
varexecutingDirectory = Path.GetDirectoryName(executingAssemblyFile);
if(string.IsNullOrEmpty(executingDirectory))
thrownewInvalidOperationException("cannot get executing directory");
vargdalPath = Path.Combine(executingDirectory, "gdal");
varnativePath = Path.Combine(gdalPath, GetPlatform());
// Prepend native path to environment path, to ensure the
// right libs are being used.
varpath = Environment.GetEnvironmentVariable("PATH");
path = nativePath + ";"+ Path.Combine(nativePath, "plugins") + ";"+ path;
Environment.SetEnvironmentVariable("PATH", path);
// Set the additional GDAL environment variables.
vargdalData = Path.Combine(gdalPath, "data");
Environment.SetEnvironmentVariable("GDAL_DATA", gdalData);
Gdal.SetConfigOption("GDAL_DATA", gdalData);
vardriverPath = Path.Combine(nativePath, "plugins");
Environment.SetEnvironmentVariable("GDAL_DRIVER_PATH", driverPath);
Gdal.SetConfigOption("GDAL_DRIVER_PATH", driverPath);
Environment.SetEnvironmentVariable("GEOTIFF_CSV", gdalData);
Gdal.SetConfigOption("GEOTIFF_CSV", gdalData);
varprojSharePath = Path.Combine(gdalPath, "share");
Environment.SetEnvironmentVariable("PROJ_LIB", projSharePath);
Gdal.SetConfigOption("PROJ_LIB", projSharePath);
///<summary>
///Method to ensure the static constructor is being called.
///</summary>
///<remarks>Be sure to call this function before using
Gdal/Ogr/Osr</remarks>
publicstaticvoidConfigureOgr()
if(_configuredOgr) return;
// Register drivers
Ogr.RegisterAll();
_configuredOgr = true;
PrintDriversOgr();
///<summary>
///</summary>
publicstaticvoidConfigureGdal()
if(_configuredGdal) return;
// Register drivers
Gdal.AllRegister();
_configuredGdal = true;
PrintDriversGdal();
I would expect that I do the GDAL initialisation correctly, including
the coordinate transformation but the "wrong" result when comparing my
results with http://epsg.io or similar sources indicate that I am
missing something essential? I have spent a long time trying to find a
solution to this issue, but with out result.
Looking forward to receive any suggestion of what might be wrong in my
approach.
Many thanks in advance.
BR
-Morten Breiner
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190310/7b5383fb/attachment-0001.html>
