[gdal-dev] ReadRaster memory hit
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Mon Mar 11 22:56:34 PDT 2019
I am writing a python script and I need to read certain pixels form a huge Hyperspectral images with over 200 band. If I use the method below from the tutorial, if I understand correctly, memory hits will only come from what I place in the buffer? In this case, only one line of pixels? Therefore, even if the raster is huge, only that one line of pixels will actually be in memory?
Thanks
Nicolas
scanline = band.ReadRaster(xoff=0, yoff=0,
xsize=band.XSize, ysize=1,
buf_xsize=band.XSize, buf_ysize=1,
buf_type=gdal.GDT_Float32)
