[gdal-dev] Export to Geopackage
Randal Hale rjhale at northrivergeographic.com
Thu Mar 14 12:36:12 PDT 2019
Much thanks to you and Dan again - this ogr statement keeps growing in
complexity and I completely forgot about the nlt option.
Thanks!
Randy
On 3/14/19 11:16 AM, Even Rouault wrote:
> On jeudi 14 mars 2019 11:11:42 CET Randal Hale wrote:
>> If I export a postgis table to geopackage:
>> ogr2ogr -f GPKG  export.gpkg  PG:"host=gis1 user=rjhale dbname=dbname
>> password=pass" -nln "addresspoints" -sql "select id, geom, addresses"
>> I check the geopackage:
>> rjhale at gis7:~/temp$ ogrinfo -so -al TCStransport.gpkg
>> INFO: Open of `TCStransport.gpkg'
>>         using driver `GPKG' successful.
>> Layer name: addresspoints
>> *Geometry: Unknown (any)*
>> Feature Count: 23735
>> Any idea on what I'm doing wrong - the unknown geometry seems to be
>> causing an issue in another process. If I export without the SQL
>> statement everything is fine.
> Randy,
> You aren't doing something wrong. This is just that the PostGIS driver cannot
> retrieve the layer geometry type if using a SQL statement (could perhaps be
> improved in simple situations where selecting from a single table without join
> or transformation on the geometry). You can force the output layer geometry
> type by adding -nlt POINT|LINESTRING|POLYGON|etc.
> See doc of -nlt in https://gdal.org/ogr2ogr.html
> Even
Randal Hale
https://www.northrivergeographic.com
(423)653-3611
