[gdal-dev] Troubles with PAM file
Even Rouault even.rouault at spatialys.com
Wed Mar 20 07:57:53 PDT 2019
Dominique,
> I'm trying to read a raster georeferenced with ArcGIS. It's a jpg file
> coming with a PAM file (.aux.xml) that store GCPs and define a polynomial
> transformation of order 3. Unfortunately GDAL does not take the PAM file
> into account and gdalinfo does not report GCPs. After some investigations,
> I found this commit
> <https://github.com/OSGeo/gdal/commit/f8822eb50466fb740e228b8c6a7f066b916faa
> 0a> that suggest PAM files are supported by GDAL but only for TIFF dataset.
Not really. PAM files are supported for most formats, included JPEG, but the
ESRI specific GCP decoding was limited for now to the GTiff format, mostly
because of the oddity you noticed: in the case for which this was developed
for
(see https://lists.osgeo.org/pipermail/gdal-dev/2017-January/045854.html and
the related email thread), pixel coordinates were indeed surprisingly in
inches and from the bottom left origin. So I couldn't/didn't want to
generalize that to core PAM processing.
> I'm a bit confused with theses PAM files, is there any technical doc from
> ESRI?
Not to my knowledge. Initially PAM was developed for GDAL itself, but it seems
ESRI developed some extensions on top of it, like the one you are facing to.
> The file can be downloaded here :
> https://drive.google.com/drive/folders/1hZXncJhcfZI0Uem-oCfUsruO9mPwWD0U?usp
> =sharing
You didn't include the most interesting part, that is the .aux.xml file itself
Even
http://www.spatialys.com
