[gdal-dev] Check of sibling files when opening an image file
Armin Burger armin.burger at gmx.net
Mon Mar 25 08:37:22 PDT 2019
Just in case someone is interested in a solution for this issue:
The most efficient setting was to set the gdal option
   GDAL_DISABLE_READDIR_ON_OPEN=EMPTY_DIR
This can reduce the file stat/open calls noticeably, depending on the
raster format. The worst format I found was JP2, which is now
unfortunately more often used like e.g. in Sentinel-2 data. For a JP2
image, a gdal Open() request for a single JP2 file makes 46 file
stat/open calls... With the above setting this is reduced to 6. In order
to set this as default, one needs to change this in the source code in
file gcore/gdalopeninfo.cpp.
If in addition the option GDAL_PAM_ENABLED is set to NO, then another 5
stat/open calls are eliminated. Here this setting can be put as default
at compile time by adding to the "configure" script the option
   --without-pam
Cheers
Armin
On 21/03/2019 19:54, Armin Burger wrote:
> On 21/03/2019 19:09, Even Rouault wrote:
>> On jeudi 21 mars 2019 18:34:11 CET Armin Burger wrote:
>>> Hi all
>>> When gdal opens a file, it checks for various sibling files, like *.MTL,
>>> *.aux.xml, *.RPC, etc (this is the case when the full directory scanning
>>> is deactivated). This can be ~30 stat or open requests when opening a
>>> single image file. Is there a way to define the file types that gdal
>>> checks for their existence, thus allowing to reduce this to the pure
>>> minimum, like *.ovr files only? Is this check driver dependent?
>> If using /vsicurl/ and derived file systems, you can use
>> CPL_VSIL_CURL_ALLOWED_EXTENSIONS=".tif,.ovr" for example
>> Even
> Hi Even
> Thanks, but we're using a POSIX file system (mounted via FUSE client),
> so I assume this will not work then.
> It would also be fine for us to reduce the number of extensions at
> compile time by modifying configuration or source code files. But so far
> I haven't found any appearances in the source code files for file
> extensions that are obviously by default checked for their existence,
> like e.g. "RPC.TXT". So any hints if/how this is possible would be great.
> Cheers
> Armin
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
