[gdal-dev] Troubles with PAM file
Dominique Lyszczarz domlysz at gmail.com
Tue Mar 26 09:20:41 PDT 2019
If it can be useful to anyone facing the same issue, my little script for
parsing these aux.xml and writing the expected GDAL commands to rectify the
raster is available here https://github.com/domlysz/PAM-GCPs-warper
Regards
Le mer. 20 mars 2019 à 18:09, Dominique Lyszczarz <domlysz at gmail.com> a
écrit :
> Thank you Even for these informations, that's good to know. I've added the
> .aux.xml in the repository if it can be useful as reference. Finally, I got
> good results with gdal_translate -gcp option following by gdalwarp. Fun
> fact, in the PAM file Y image coordinates are negatives values but must be
> pushed as positive number in gdal_translate command.
> Le mer. 20 mars 2019 à 15:57, Even Rouault <even.rouault at spatialys.com> a
> écrit :
>> Dominique,
>> > I'm trying to read a raster georeferenced with ArcGIS. It's a jpg file
>> > coming with a PAM file (.aux.xml) that store GCPs and define a
>> polynomial
>> > transformation of order 3. Unfortunately GDAL does not take the PAM file
>> > into account and gdalinfo does not report GCPs. After some
>> investigations,
>> > I found this commit
>> https://github.com/OSGeo/gdal/commit/f8822eb50466fb740e228b8c6a7f066b916faa
>> > 0a> that suggest PAM files are supported by GDAL but only for TIFF
>> dataset.
>> Not really. PAM files are supported for most formats, included JPEG, but
>> the
>> ESRI specific GCP decoding was limited for now to the GTiff format,
>> mostly
>> because of the oddity you noticed: in the case for which this was
>> developed
>> for
>> (see https://lists.osgeo.org/pipermail/gdal-dev/2017-January/045854.html
>> and
>> the related email thread), pixel coordinates were indeed surprisingly in
>> inches and from the bottom left origin. So I couldn't/didn't want to
>> generalize that to core PAM processing.
>> > I'm a bit confused with theses PAM files, is there any technical doc
>> from
>> > ESRI?
>> Not to my knowledge. Initially PAM was developed for GDAL itself, but it
>> seems
>> ESRI developed some extensions on top of it, like the one you are facing
>> to.
>> > The file can be downloaded here :
>> https://drive.google.com/drive/folders/1hZXncJhcfZI0Uem-oCfUsruO9mPwWD0U?usp
>> > =sharing
>> You didn't include the most interesting part, that is the .aux.xml file
>> itself
>> Even
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190326/781e3e41/attachment.html>
