[gdal-dev] Polymesh vs Faces as DXF blocks
andrew terry andrew.terry at centremaps.co.uk
Thu Mar 28 02:41:35 PDT 2019
Running the DXF exporter using a "Polymesh" block (e.g. a simple sphere)
fails but if i explode the polymesh to get "Faces" and use that as my block
my export works.
Just wondering whether there is any known reason for this - i'd thought the
block was not actually processed and just referenced in the process.
I have to swap the block manually to a polymesh after the export for it to
work in another application.
Using GDAL 2.4.0
Thanks
Andy
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
