[gdal-dev] Polymesh vs Faces as DXF blocks
andrew terry andrew.terry at centremaps.co.uk
Thu Mar 28 02:46:05 PDT 2019
Just to add...
The result is the points are exported to the file and no block when it is a
polymesh. I've tried the template file as various options from R12 to
2004-2006 DXF
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
