[gdal-dev] Should the next version (previously 2.5) be called GDAL 3.0 ?
Mateusz Loskot mateusz at loskot.net
Wed May 1 13:46:19 PDT 2019
On Wed, 1 May 2019, 20:56 Even Rouault, <even.rouault at spatialys.com> wrote:
> Hi,
> As a feedback from the previous motion, it appears that GDAL 3.0 would
> probably better reflect the API & behaviour changes that have been done,
> and
> be in accordance with our HOWTO-RELEASE procedure and semantic versionning
> rules.
> I'm OK with that change
I'm not claiming right to vote here.
Although I haven't been too active as contributor for quite some time, I'm
not indifferent. I'm active user and I do
monitor what's happening and I think calling the next release 3.0 is a good
idea.
Mateusz Loskot, mateusz at loskot.net
(Sent from mobile)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190501/9b6da6ed/attachment.html>
